เลือกบอร์ดถูกรึป่าวครับ
ออผมยังไม่ได้ลงไลเบอรี่บอด ซักครู่ครับ
Arduino: 1.8.10 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\User\Desktop\a\a.ino: In function 'void sendUptime()':
a:74:2: error: 'sensors_event_t' was not declared in this scope
sensors_event_t event;
a:74:18: error: expected ';' before 'event'
a:75:6: error: 'class DHT' has no member named 'temperature'
a:75:30: error: 'event' was not declared in this scope
a:80:6: error: 'class DHT' has no member named 'humidity'
Used: C:\Users\User\Documents\Arduino\libraries\ESP8266WiFi
Not used: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.1\libraries\ESP8266WiFi
Multiple libraries were found for "BlynkSimpleEsp8266.h"
Used: C:\Users\User\Documents\Arduino\libraries\Blynk
Multiple libraries were found for "DHT.h"
Used: C:\Users\User\Documents\Arduino\libraries\DHT
Multiple libraries were found for "SimpleTimer.h"
Used: C:\Users\User\Documents\Arduino\libraries\SimpleTimer-master
Multiple libraries were found for "Adafruit_Sensor.h"
Used: C:\Users\User\Documents\Arduino\libraries\Adafruit_Unified_Sensor
วางโค้ตล่าสุดมาหน่อย
#define DHTPIN D4 // กำหนดขาให้กับอุปกรณ์ตรวจสอบความชื้น DHT11
#define DHTTYPE DHT11
//////////////////////////////////////////จุดที่เพิ่ม
int setTemp;
int setHumid;
BLYNK_WRITE(V4) //temperature slider in app on pin V22
setTemp = param.asInt();
BLYNK_WRITE(V3) //temperature slider in app on pin V23
setHumid = param.asInt();
//* **BLYNK TOKEN** //
char auth[] = "XXXXXXXXXXXXXXXX";
char ssid[] = "AndroidAP";
char pass[] = "123654789a";
void sendSensor()
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(D1, OUTPUT); // ***ควบคุมอุณหภูมิ*** ///
digitalWrite(D1, HIGH);
void sendUptime()
// *****ชุดคำสั่งการทำงานของอุณหภูมิ***** *//
Blynk.virtualWrite(V5, millis() / 1000);
if (!isnan(event.temperature)) //ตรงนี้เป็นการกำหนดเงื่อนไข >=, <= , == ใช่ไหมครับ
Blynk.virtualWrite(V1, event.temperature); //หรือผมต้องมากำหนด เงื่อนไข >=, <= , == ตรงนีครับ
if (!isnan(event.relative_humidity)) {
Blynk.virtualWrite(V2, event.relative_humidity);
//if(Blynk.connected()) {
เอาล่ะมีซำติงแน่นอน55555555
ผมควรเริ่มเขียนใหม่ใช่ใหมครับ ท่าใช่อยากให้ช่วยแนะนำการดึงค่าอุณหะภูมิมาเปรียบเทียบกับค่าปุ่มในบลิ้งหน่อยครับ
แก้เป็นแบบนี้ครับ มันมีหลายฟังก์ชันที่ซ้อนทับกันอยู่
และ library ที่เขียนกันคนละแบบเอามาใช้ที่เดียวกันจะไม่ได้ครับ
int setTemp;
int setHumid;
void sendSensor()
// Read temperature as Celsius (the default)
Blynk.virtualWrite(V1, t); //หรือผมต้องมากำหนด เงื่อนไข >=, <= , == ตรงนีครับ
Blynk.virtualWrite(V2, h);
Serial.println("Humidity: ");
Serial.print(h + String("%"));
Serial.println("Temperature: ");
Serial.print(t + String("c"));
สีแดงๆคือผิดผมเข้าใจถูกไหมครับ
ที่ลบออกไปครับ เขียวคือเพิ่มเข้ามา
แล้วโด้ดเปรียบเทียบนี่จะทำยังไงหลอครับ
ขยายความหน่อยครับว่าเปรียบเทียบอะไรแบบไหน
ต้องการเปรียบเทียบ “ค่าอุณหะภูมิ กับ Widget Numeric Input ท่าอุณหะภูมิมากกว่าที่Widget Numeric Input กำหนดใว้ให้สั่งรีเลย์ทำงาน”
“ความชื้น กับ Widget Numeric Input ท่าความชื้นน้อยกว่า Widget Numeric Input กำหนดใว้ ให้สั่งรีเลย์ทำงาน”
ตอนนี้คอมไพ ผ่านรึยัง
ผ่านแล้วครับ
เดียวผมจะเขียนกระทู้มาตอบเรื่องนี้ให้นะครับ ต้องอธิบายหลายส่วน เดียวเอามาแปะไว้ให้
ขอบคุนมากๆครับ ติดกับโค้ดนี้มานานมากๆแล้ว
