Relay ไม่ทำงานตามคำสั่ง แก้ยังไงดี
อันนี้โค้ดของผมทั้งหมดครับ
คือ relay ผมไม่ทำงานตามที่สั่งไป
ช่วยดูโค้ดให้ผมหน่อยครับ ว่าผมผิดตรงไหนหรือเปล่าครับ
ขอบคุณมากครับ
  This is a simple demo of sending and receiving some data.
  Be sure to check out other examples!
// Template ID, Device Name and Auth Token are provided by the Blynk.Cloud
// See the Device Info tab, or Template settings
#define BLYNK_TEMPLATE_ID           "TMPLf_VEI5xH"
#define BLYNK_DEVICE_NAME           "Quickstart Device"
#define BLYNK_AUTH_TOKEN            "X5zwImlUNpugTUixUBav5_NeUB345PWx"
// Comment this out to disable prints and save space
#include <PMS.h>
#define relay D2
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "E = mc2";
char pass[] = "zxkeq8vo9i931";
PMS pms(Serial);
PMS::DATA data;
byte auto_relay = 0;
float dust_auto = 0;
// This function is called every time the Virtual Pin 0 state changes
  // Set incoming value from pin V0 to a variable
  auto_relay = param.asInt();
  digitalWrite(relay, LOW);
  // Update state
// This function is called every time the device is connected to the Blynk.Cloud
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
  Blynk.setProperty(V3, "onImageUrl",  "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
  Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
  pinMode(relay, OUTPUT);
  lcd.begin();
  lcd.display();
  lcd.backlight();
  lcd.clear();
  //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
  Blynk.connect();
  if (pms.read(data)) {
    Serial.print("PM 2.5 (ug/m3): ");
    Serial.println(data.PM_AE_UG_2_5);
    lcd.begin();
    lcd.display();
    lcd.backlight();
    lcd.setCursor(1,0);
    lcd.print("Dust : (ug/m3)");
    lcd.setCursor(0,1);
    lcd.println("PM 2.5 : ");
    lcd.println(data.PM_AE_UG_2_5);
    Blynk.virtualWrite(V2, data.PM_AE_UG_2_5);
ต้องการให้สั่งให้อะไรทำอะไรครับ
ให้พัดลมทำงานครับ
สั่งเปิดปิดพัดลมด้วย relay อะครับ
คือว่า relay มันทำงานแบบว่าเปิดตลอดเวลาเลยครับ
ผมเขียนโค้ดให้เป็น LOW กับ HIGH แล้ว
relay ก็ยังทำงานเหมือนเดิมเปิดตลอดเวลสที่มีไฟเข้าครับ
ปุ่ม หน้าแอพกำหนดยังไง
น่าจะติดตรงนี้ เนื่องจากไม่ได้กำหนดเงื่อนไงไขว่ารับ high/low แล้วให้ทำอะไร รับมาก็ให้ Relay เป็น low อย่างเดียว
ดูตัวอย่างการเขียน
ผมอัพโหลดโค้ดใหม่ตามนี้ครับ
ตอนผมกด off ไฟที่บอร์ดติด พอกด on ไฟที่บอร์ดดับ
แต่ไฟ relay เปิดทั้งคู่เลยครับ
อันนี้โค้ด
#include <PMS.h>
char relay = 2;
PMS pms(Serial);
PMS::DATA data;
  lcd.begin();
  lcd.display();
  lcd.backlight();
  lcd.clear();
  Blynk.connect();
  if (param.asInt()==1){
    digitalWrite(relay, HIGH);
  else{
  // Update state
    lcd.begin();
    lcd.display();
    lcd.backlight();
    lcd.setCursor(1,0);
    lcd.setCursor(0,1);
Relay ต่อพินไหนไว้ครับ
relay ในแอพ blynk ต่อ pin1
ส่วนที่บอร์ดต่อช่อง D2 ครับ
พิน 2 คือ led บนบอร์ด ครับ เปลี่ยนพินใหม่ทั้งโค้ตและบอร์ด
ถ่ายการต่อมาดู้วนครับ
#include <PMS.h>
char relay = 2;
PMS pms(Serial);
PMS::DATA data;
  lcd.begin();
  lcd.display();
  lcd.backlight();
  lcd.clear();
  Blynk.connect();
  else{
  // Update state
    lcd.begin();
    lcd.display();
    lcd.backlight();
    lcd.setCursor(1,0);
    lcd.setCursor(0,1);
    Blynk.virtualWrite(V1, data.PM_AE_UG_2_5);
บอร์ดผมต่อสายตามรูปนี้เลยครับ
บอร์ดที่ใช้มีไฟ 5V รึป่าว
มีครับ แต่ผมต่อไฟ 5V ออกมาผ่าน protoboard ครับ เนื่องจากว่า ไฟ 5V ต้องมาเลี้ยงอุปกรณ์อีก 3 อย่าง คือ ตัววัดฝุ่น จอLCD และก็ relay ครับ
ลองย้ายพินบนบอร์ดดูก่อนว่าได้ไหม สัญญาณมันอาจจะใช้ควบกับ led ด้วยทำให้ไม่พอที่จะทิก relay รึป่าว
แล้วก็ถ่ายที่เราต่อมาดูด้วย เอาที่ต่อตามรูปมาไม่สำคัญเท่าเราต่อเองครับ
พอมองออกมั้ยครับ ผมลองเปลี่ยนมาใช้ D8 ดูครับ
ไฟ relay ติดตลอดแต่ไม่ทำงานตามคำสั่งครับ
แล้วก็ไฟที่บอร์ดเปิดปิดตามคำสั่งหายแล้วนะครับ
เรามี relay ตัวอื่นไหมเอามาเทสหน่อย มันควรจะออกนะนิ
งั้นเอางี้ ง่ายๆ เลยลองเอาพินที่สั่งนั้น ต่อ led นอกดูเลยครับ ถ้ามันทำตามที่เราสั่งคือจบที่ relay เสีย
